Pictures would help considerably so we can see caster and camber etc.
Do you have your wheels straight or did you use some tow out?
Some trikes change their steering angles/set-up when loaded as opposed to unloaded.
0 to 3mm toe-in max on a tadpole. Some trikes change their steering angles/set-up when loaded as opposed to unloaded.
I had quite a bit of trouble on mine until I made some adjustable toe-in setting sticks. Now it is perfect, on a flat uncambered surface I can even ride hands off for short distances (until it hits a bump).
Tweren't one taken. You will have to take my word for it. ;-)Well don't be shy .....
Share the video !
