Brad, have you thought of designing hubs for trikes that can use bottom brackets as the hub and bearings, might support more weight the the standard hubs.
the square one would just need spoke flanges to be welded on and the square taper could be cut into a square hole on mounting flange on the trike and secured with a bolt.
could also use the old cranks with the flat side to secure with the jam screw.
Doug
Doug
