The steering rods need to be mounted in front of the part where the front part is mounted to the base frame. In the rear it needs to be on the other side.
Ackerman and angle of the points where the frame is mounted to the rear and front parts, make his much steering and tilt you have.
As you ad handlebars, it is probably better to havd the tod that go to the front and rear, closer ad the center ad the handlebars and wider ad the front and rear. This to lower the steering input.
With front and rear, you get more steering with front and rear steering. This way the quad will be less nervous.
