Front wheels Street Fox
Looking for front 20” wheels 36 to 48 spoke with 9/16”,(14mm).
I have a few questions,#1- can you use rear wheels, just take off sprocket.
#2- what kind off wheel would I buy that I could change the axle from 3/8 to 9/16 , if that would even be possible?
#3- I know there are wheels out there, put I don’t want to pay $200.00 plus.
This has been a stumbling block in my Street Fox build.
Rear wheels often have a longer hub than fronts to allow room for the sprocket and also often have the hub offset from the central line of the rim. none of that is any issue but using the front and rear from the same donor will not likely yield matching wheels. 14mm axle wheels ought to be sub $40 each on ebay.
