Lubed...Yes. Both inside and on the shaft, just before using.Have you lubed it? It may also be a bent cutting pin - they are a consumable.
Bent .....Maybe, but it runs at full rpm when not cutting.
If you mean is there a piece stuck in the cutting head.....no.Does it jamb with a nibbled piece in it?
It stops and I have to pull back on the nibbler to free it from the jamb. Just as the instructions say, to do.
But when I try it again, it will only cut two nibbles and stops again.
Maybe the pin cutting edge has dulled already. I've cut an estimated 10 feet with it.
If the pin is dull this quick, it will take a boat load of pins, to do simple projects.
It didn't come with an extra pin, so I'll have to get some, and see if that is the reason its stopping.
Thanks for the input guy's.
