They are just idlers on the ICE VTX? And does that machine have a rear swingarm arrangement with a shock like the Streetfox? Can't see one in the pic unfortunately. Wow that machine looks like it is moving fast while sitting still! But I don't know how comfortable it would be to "ride" / lay on?I posted the picture of the ICE VTX racing trike. As that has the most clear view of the 2 idler idea for the chain line.
My own Grey Ghost has only 1 idler. And that machine is the opposite of a racing trike.
Not sure how a mid drive motor would fit into the Warrior/Streetfox scenario, and since the rear wheel (direct drive) motor is whisper quiet, I don't think the weight down low back there is an issue. Also there is no chain jerking during shifting with a direct drive motor since the force is applied directly to the ground and not thru the chain. (I had one of these and they have no gear noise which I love) (no gears inside the motor)A battery will be about 4-5kg and will fit nicely on the front boom. Alternately you can make a carrier for it under the seat on the non chain side. You absolutely do not want it above the rear wheel. Wheel motors are very heavy but a Tongsheng tsdz2 is 3.8kg and a lot nicer to use than the wheel motors.
How so? It must be a special arrangement?The chain doesn't jerk during shifting with a mid drive either.
What is an IGH?With a Mid Drive you can use IGH's, what is a huge benefit if you want troublefree riding. No fiddling around with rear shifters that are finickey to adjust.
Internal Gear Hub.What is an IGH?
Just as atandard. Why should it jerk?How so? It must be a special arrangement?
Never owned anything but hub motors, but let's say the mid drive motor is pulling you along. Now there's some chain tension, and let's say that the trike is equipped with a deraileur on the rear wheel. Then we go up a hill. Now we want to change gears to something lower so as to maintain speed. So how can we shift gears without a jerk on the chain system? Do we have to throttle back on the power to take the load off the deraileur to avoid yanking into the new gear or how does that work? I think the mid drive motors are built around the cranks and they can sense the cadence, but unless you temporarily reduce the pedal cadence or force somehow, the chain would feel the crunch.Just as atandard. Why should it jerk?
One last thing - motor noise from a mid drive motor = ICE Adventure 5,000 Mile Review | ICE Adventure - YouTubeNever owned anything but hub motors, but let's say the mid drive motor is pulling you along. Now there's some chain tension, and let's say that the trike is equipped with a deraileur on the rear wheel. Then we go up a hill. Now we want to change gears to something lower so as to maintain speed. So how can we shift gears without a jerk on the chain system? Do we have to throttle back on the power to take the load off the deraileur to avoid yanking into the new gear or how does that work? I think the mid drive motors are built around the cranks and they can sense the cadence, but unless you temporarily reduce the pedal cadence or force somehow, the chain would feel the crunch.
But a hub motor will over run (reduce) the chain tension if there is more throttle added. This puts slack in the system and assuming the pedals are spinning a bit, the deraileur is happy and goes to whatever gear is selected- just like it does on the bike stand when you are testing the shifting. Of course you may or may not be adding to the bike's progress unless you once again have selected the correct gear, but you are still going up the hill and the chain never sees any abuse.
Mid drive motor noise - see this You Tube video - ICE Adventure 5,000 Mile Review | ICE Adventure - YouTubeWith a Mid Drive you can use IGH's, what is a huge benefit if you want troublefree riding. No fiddling around with rear shifters that are finickey to adjust.
