Warrior seat mod question
I am modifying a warrior I made to use a sun seeker mesh seat. This is how I plan to hvae it, rifht now everything is just tacked or hel in place with Magnets. Does it look like it will work, there is enough support , etc.
Basically the seat is sitting kn a bolt for the bottom, iI added a plate to the frame and welded couplers to the plate to distribute the weight.
Mid way up the back i added a half a piece of pipe welded to 1" square tube that is bolted to the back rest support
And at the top two arms that connect on an angle to the back rest and a half piece of pipe welded to 1.5" square tube against the back rest also.
Looks plenty strong enough. If anything there's quite a bit of metal I'd have omitted. I'd have used just a top and bottom mount. On the bottom I'd simply weld the two black vertical bits to the chassis and omitted all the other bits and done the same to the top as you have.
That's how they come from the factory, sitting on a bolt on the bottom and two pipes to the supports at the top, but I was worried about the weight being in so few places on the frame itself, the seat before was from the plans so the board was on the whole frame.
