Hi velocoupe,
thank you for taking the time to answer my questions. Sticking to your analogy, then I would most probably like to build a coupe style sports sedan
and I totally get your point. After doing some further analysis, I will most probably reduce the roll cage design of the begorett to a bare minimum, probably one arch behind the head/rider and one to cover the knees. Fortunately, I will work with chromoly tube which hast a pretty good strength to weight ratio.
Before I go straight to the drawing board, I would further describe the intended use of the vehicle and also I still have some more questions:
In my case, the velomobil, will be used to commute around 30km in total a day. Most of the time in urban terrain (narrow bike lanes or roads) with low to medium climbs. Since we have a lot of cars in the city, I'd like to feel as safe and visible at all time, but also want to have a good view of sight. The mobil will be assisted, therefore it doesn't need to be super light. The idea is to be able to easily reach 30km/h.
Now to my questions
1. Is the TILT worth the extra effort?
I can definitely see some engineering problems compared to a "traditional" trike or velo quad. It seems that finding the right balance of the system could be difficult, not to mention the more complex mechanical design.
So do you think in general, but also for my purpose, is it worth going down this road?
2. How would your design differ from what you have now if you could start again?
Based on your current observations, are there any fundamental changes you would make to the design to make it simpler, make the tilting feel better, or generally improve the riding experience?
3. Combined steering
Although it seems, you can get used to the thumb steering, I fell like there is room for improvement. Do you have any concept to combine the two steering systems into one lever/motion? Or do you think the system is good as is?
Thanks a lot
