The next project is started. The quad isn't finished yet, but i started with designing the next trike.
I am now working on a suspension design. As inspiration i used the steintrikes. I will do a similar front suspension and steering. It is a simple design that is easy to make. The only thing i do, is using ball bearings on the suspension arms on the side of the frame.
The things i like on the steintrike is that you can easily change it into something else. That is why i do the same.
I also will use round tubing from stainless steel.
We will ad least build 3 trikes. For maddox, badass cycles and one for me. But probably it will be 5 trikes.
2 other people want one to.
Because some people have other wishes, it is nice to have a trike like the steintrikes where you can swap things out. The center will be by all the same, but Maddox wants something different from what i want. One of the other people want an other drive train in the front.
So making the base the same, makes it easier to build the different trikes.
I want it with 20inch all around, but others want 26inch all around.
With of the front will be 90cm. That is wider than most trikes, but this so it is more stable and it works better as you use 26 inch wheels.
If it is to wide for some people, then i only need to make the arms s bit shorter. That isn't that hard.
The front suspension.
Added a bit more so i can see how much space i have for the steering and how i will do the chain line.
