I think the pivot that allows it to "fold-up" like it does is a simple sleeve over a round tube with a spring-loaded locating pin that can be pulled.
The whole driveline (cranks, chain, Internal geared hub) is self-contained in the front section. So all of that is forwards of the pivot and only the front wheel is driven. As the maker says, if required a rear wheel could also be driven by inserting a hub-motor instead of a normal rear hub for e-assist.Please accept my apologies if this is obvious as I am visually impaired at the moment. Does this have driveline gearing? I have been asking manufacturers to consider making a foldable Delta Trike for years but they never felt there was a market. Hope you get it to the plans stage.
DannyCI think I know a way to do this, I will cut up some tubes and let you know if I am right.
