Carla Cargo Trailer: Licence free plans for the home builder.
Here is a link to the plans and cutting list for the Free Licence open source plans for the Carla Cargo Trailer.
The Plans: www.werkstatt-lastenrad.de/index.php?title=Bauanleitung_Carla_Cargo_Crowd Google Translate will be your friend
The cutting list: www.mig-welding.co.uk/forum/threads/lawn-mower-bike.91811/page-2#post-1370650
To simplify things:
Assume 20x 20x 1.5 is equal to ¾”x¾” x 16 gauge ERW (Electric Resistance Welded) square section tubing.
Assume 15x 15x 1.5 is equal to ⅝”x⅝” x 16 gauge ERW square section tubing.
Assume 20x 50x 1.5 is equal to ¾”x2" x 16 gauge ERW rectangle section tubing
Assume 40x 3x is equal to 1&⅝” x ⅛" Mild Steel Flat
Materials list:
  • 1x 20x10x1,5x6000mm ERW square section tubing.
  • 3x 20x20x1,5x6000mm ERW square section tubing.
  • 1x 20x50x1,5x6000mm ERW square section tubing.
  • 1x 15x15x1,5x6000mm ERW square section tubing.
  • 1x 20x20x2x6000mm mild steel box section
  • 1x 40x3x6000mm mild steel flat
Here is a complete steel cutting list
Material 20x20x1,5mm cut angles 90° & 90° Length 1625mm qty 4
Material 20x20x1,5mm cut angles 90°& 90° Length 150mm qty 4
Material 20x20x1,5mm cut angles 90°& 90° Length 110mm qty 6
Material 20x20x1,5mm cut angles 60°& 60° Length 152,5mm qty 6
Material 20x20x1,5mm cut angles 60°& 72,5° Length 1400mm qty 2
Material 20x20x1,5mm cut angles 55° & 72,5° Length 230,1mm qty 2
Material 20x20x1,5mm cut angles 90°& 90° Length 112mm qty 4
Material 20x20x1,5mm cut angles 60°& 90° Length 53,8mm qty 4
Material 20x20x1,5mm cut angles 60° & 90° Length 53,8mm qty 4
Material 20x20x1,5mm cut angles 90°& 90° Length 610mm qty 4
Material 20x10x1,5mm cut angles 90°& 90° Length 610mm qty 5
Material 20x50x1,5mm cut angles 90°& 90° Length 110mm qty 1
Material 20x50x1,5mm cut angles 90°& 90° Length 400mm qty 1
Material 20x50x1,5mm cut angles 90°& 90° Length 200mm qty 1
Material 20x20x1,5mm cut angles 30°& 30° Length 150mm qty 2
Material 20x20x1,5mm cut angles 15°& 45° Length 150mm qty 2
Material 20x20x2mm cut angles 90°& 90° Length 100mm qty 1
Material 20x20x2mm cut angles 90°& 90° Length 150mm qty 1
Material 15x15x1,5mm cut angles 90°& 90° Length 850mm qty 1
Nice project, thanks for posting. Did you have a handin the design?
No, not in the design of the Carla Cargo products, but I know the guys from meeting them at various shows and the annual International Cargo Bike Festival.
Until a couple of years ago when I retired due to ill health I built cargo carrying bicycle frames, pedal power utility quad vans and trucks, pedal powered racing cars, sail trikes, pedal powered cultivation tool carriers for in side glasshouse use, down hill/gravity soapbox racer frames and I've even built some AZ Warrior trikes.
Perfect rear for a python loader, hmmm.
I thought that at first and then realised the rider would be sat in the cargo area DOH !
